Bent steering tube on double cable
831Bass
wha could have caused this? Repower with a jack plate so I guessing the tension of cables to the hull it too much? Can I run it one cable for the weekend? Can I ratchet strap it straight and put a brace on it?
oldboat1
Steering ram might not be bent (tilt tube only). If so, could replace the tube. Tilt clearance looks suspicious as a cause -- hard to say.
Hate to say much in the way of fixes, as that stuff can be pretty dangerous.
boobie
Repair the steering correctly before using !!!!! It's to dangerous if not done properly !!!!
831Bass
You guys were right! jackplate was the problem. I got the tube straightened out and shaved the interfering corner of the plate to make it clear the tube. Can tilt up almost all the way now and it turns a million times easier and smoother. Thanks for the help again lovin this board!
