solidruby192
Thread starter- Joined
- Jul 4, 2005
- 1
Hi , <br /><br />I'm wondering if I have a bent prop shaft.<br /><br />I have a newer BR w/the 4.3 engine and alpha one lower unit. Anyway I hit some earth in the middle of the lake at about 30 mph.<br /><br />The boat had a 21 p alum prop that was only moderately bent and the nose cone (or gear case nose) looked like it just went into orbit, I refinished the gear case and it looked good after sanding and paint. The skeg wasn't really damaged w/the exception of paint...<br /><br />Took the boat to the prop shop where the guy put a dial indicator on the prop shaft - at the base it's 5 1/2 thousands off and at the tip (actually on the spline) it's o nly 2.0 thousands out... He wasn't sure what the allowable distance is for a bent shaft??? <br /><br />Was wondering if anybody knows about the spec's on the shaft... <br /><br />Thank you,
