Re: bennical mount
double check where which hole in the binnacle mount that you installed the shift cable connector. It goes in the INSIDE hole, not the outer one. Also look at the cable from the end, it should be parallel to the metal sides of the binnacle if it is positioned on the correct side of the shift lever. You can get a binding condition if on the wrong side.
