Bendix Not Engaging Flywheel
Snacksy69
I have a 1980's Evinrude 90 hp, 4 cylinder outboard that will not start.
It has run steadily and without problems for many years and gets its annual wintering and spring service by a professional each year.
What first seemed like an electrical problem may be something different. I am handy enough to fix most things, if pointed in the right direction, so I am wondering if anyone here can point me in the right direction.
The problem seemed to start with a dead battery. It turned over weakly and after a few tries at starting was barely turning over, like an old car on a cold winter morning. I took the battery out and my battery charger read it as being only 25% charged. I gave it a full charge and that gave the motor some life, but only as a grinding sound. The bendix does not seem to engage the flywheel, instead just grinding against it. The flywheel can be manually turned all the way around. The flywheel teeth are perfect, but the bendix teeth are a bit worn.
Thinking it had to be related to electrics, I have replaced spark plugs and cleaned all the connections through the entire electrical system, but no change.
My first assumption would be the Bendix teeth, but I cannot help but think it must be connected to electrical issues.
I have posted a video of a start attempt and a close-up of the Bendix here: https://youtu.be/TMpgOh9Yrpw
Any thoughts where I should start with diagnostics? Or any opinion if this is too big of a problem for a home fix (in that case, I will call it a season and have a professional look it over simultaneous to winterizing.
Honorary Supreme Mariner
Bendix gear needs to be replaced.--------------And if it has never been worked on the starter needs to be torn down.-----------Inspected and test the armature.----------New brushes are likely needed as well.----------All simple stuff if you do it yourself.----------------If money is not a problem then a complete new starter is the best option.
jakedaawg
I agree with racer completely however I might add....
Load test battery, checking with a voltmeter tells little.
Inspect battery cables for corrosion and general condition. Remove each end and ohm check them, you should get a very low reading. Clean all battery cable ends and battery posts till shiny. Tighten with a wrench, wing nuts don't count and should be thrown away.
Snacksy69
OK. I will go through the battery and cables first, just to make sure. If that does not work, I will replace the Bendix gear while looking at the starter for possible tear down or replacement. I will let you know what I find. Thank you for the assistance!!
jakedaawg
Starter definitely needs to be torn down and inspected/replaced as well as bendix.
My comment was to check things that could have lead to the failure you have expeienced.
Fed
Looks like the starter motor is moving sideways when it engages the flywheel, is it securely bolted to the block?
