Belt Pulley configuration
jimrockireland
I just bought a 1983 boat with a Mercruiser 305/5L V8 and what looks like a Alpha One Gen 1 sterndrive. I was able to unseize the engine (good compression) and need to install belts. The previous owner gave me 2 belts one a little larger than the other, but I can't find the belt diagram in my Repair manual, on the engine or on-line. There are double pulleys on the crankshaft and water pump. I am guessing the larger belt goes on the outer pulleys of the water pump/crankshaft/Power steering. The smaller belt goes on the inner pulleys of the crank shaft/water pump and alternator. Does this sound right?
Bt Doctur
Re: Belt Pulley configuration
inner is crank, alt, circ pump.
outer is crank,circ pump, power steering pump
jimrockireland
Thanks for the verification. I'm surprised something so basic is so diffficult to find.
