Mark42
- Oct 8, 2003
- 9,334
Re: belly tank/stringer conflict
As long as you measured and have the space between where the new stringers will be, the hull looks fine.
Be sure to support the tank properly. Don't just lay it against the hull. A spacer is needed to let water drain freely into the bilge. Check out Lowes and look at the PVC exterior trim. They have some 1x and 2x boards that could be glassed to the hull to support the tank and they won't rot.
