nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,096
Going to be doing some R&R on my outdrive on Friday. I have on order new bellows, shift cable kit, trim senders, water hose(s)(2 different sizes available?), and U-joints (Moog 315g automotive, we'll see if they fit). I did the bellows when I first got the boat, maybe 8 seasons ago, definitely showing wear. Pulled the outdrive, and saw more damn water in the shift shaft cavity. I just replaced the shift shaft seal with the new style last season, hoping new bellows will solve it. Anyway, I'm trying to get everything done on Friday, which means NO trips to the marina/HW store/etc. I'm amassing 1/2" allen wrench, various 1/4" socket extensions, bearing presses...
2 questions, bearing in mind I have no handy marina nearby:
1. I need bellows adhesive. I'm pretty sure I used permatex aviation sealant last time around, since I use it for damn near everything. Wondering if there's something better. Can't find bellows adhesive locally. Saw mixed reviews about the sierra stuff at Napa. Can't find power tune.
2. Saw belatedly that I might need fiber washers for the hinge pins? This is exactly the kind of thing that kills me, stopping work for a $2 part. Do they usually need replaced? Looks like part # 12-72498, anything else I can use in a pinch?
Anything else at all that I should have on hand?
