I’m replacing bellows and trim senders on an Alpha 1 Gen 2. I have all OEM parts and got it torn apart this morning. I want to verify my installation order and a few other things before I start installation. I have a factory manual but it doesn’t specify the installation order.
1. Here is what I think the installation order is for the bellows: Water inlet hose, u-joint bellow, oil hose, shift cable bellow, exhaust bellow. I’m going to attach all to transom and then attach to bell housing.
2. Are the OEM water inlet hose and gear oil hose the correct length already?
3. I’m going to replace the shift shaft bushings and seals while I’m in there. What direction should the two seals face? Spring ends facing up?
4. Is it recommended to install the shift cable into the bell housing when it’s on the bench or screw it into the bell housing after I have the bell housing on and hinge pins in? (I used string trimmer line to leave me a guide.)
5. The manual says no more than two threads showing on shift cable at bell housing. When the shift cable get tight in the bell housing is it an issue sometimes with more then two threads showing? Im just curious about this.
6. Is it recommended to put the hinge pins in before attaching the u-joint bellow and retainer ring into the bell housing?
7. Do I need to use anything to secure the oil line to the fittings or it the hose tight enough?
8. Does the grounding clips on the bellows need to be in a specific location?
Thanks, I feel lucky so far that the plastic gear line fitting hasn’t broke. I have one just sitting on the bench if it does but hopefully Power Tune will slide the oil hose on without breaking the nipple.
