before i remove my motor????
jneighbors23
i have a small block chevy motor that got pretty hot and i cracked a head. i have new heads new manifolds and new risers. drained all the oil out. ran a few gallons of diesel through it.before i started bolting it back together i tryed to manually turn motor over for fun. it wont turn. i disconnected trans cable and throttle. i cant remember if i put it in neutral when i started to take it apart! prop spins freely right now. is it time for bottom end job???? rather not do it. but i will.
Re: before i remove my motor????
Ayuh,....
You'll have to Pull the Drive to see if it's the Motor, or the Drive.....
What are We working on,..??
Robj
It seems like you know the answer, you just want someone to convince you otherwise. If it got as hot as you say it did and you are replacing the head, I would do the bottom end as well. I guess that is not the answer that you wanted to hear.
Have a great day,
Rob
