beep alarm on high rpm
don juls
Ok when I have two 200hp Mercury optimax the year 2002 my problem is that suddenly have beep alarm and the engine doesn?t run more then 2200 rpm aprox. On the display have no water pressure (zero) Have some experience but I can?t find what the problem is. The water pressure sensor is ok I tried one from the other engine and still the same, Have changed pieces, sensor from one to the other and nothing, the beep is there. Have oil in the tanks, impeller is ok,have disconnected the temp sensor well? Don?t know where to go now. This is a fuel injectin model. In low rpm the beep sound three times
achris
More fish than mountain goat
Re: beep alarm on igh rpm
Swap the electronics box, you may have a faulty one.
Chris........
achris
Re: beep alarm on high rpm
This sounds like one you need to take to a Merc dealer and have them plug the SCAN tool in. It's a computer diagnostic tool and will tell you very quickly where to look.
Good Luck..........
don juls
I have the remote oil tank full but where is the oil level sensor,, don?t see it
don juls
SORRY this is Honduras, no where to go, the one that "had" the diagnosis tool is in heaven now....Ok anyway i?ll keep on trying
achris
No sensor in the remote tank, only in the tank inside the engine cover.
