voodoochikin
- May 20, 2012
- 126
Re: How do I SET the high idle when starting cold without engaging the transmission
is it possible that the fuel pump diaphram going bad, cause this issue? I watched the butterflies on the carbs while i had it in the water. they were not opening while the engine was revving up doing its thing. So if its a massive airleak, could it be from a crank seal? a visual inspection of all the gaskets doesnt appear that any have blown out causing a gap. The carbs feel tightly bolted on. everything just looks to be in the exact shape as when I parked it for the winter. This is really disheartening.
