Bedliner Useful? Don't laugh ok!?
kickinitoldfool
Has anyone ever used spray on bedliner in the bottom of there starcraft resto vs gluvit? I thought of that before I came here and was wondering if it had ever been used?
Its rubber based figured it might work. :D
64osby
Re: Bedliner Useful? Don't laugh ok!?
not recommended and a PITA if you have to ever work on the boat again.
GA_Boater
I think this is one for jbcurt00. And I think I know his answer. Paging JB.
Captmills
works on rowboats with screen doors on'em. why not a starcraft...after a whole day on the water it still floats:D:D:eek:
kickinitoldfool
LOL ya that must be where I saw that idea! LOL the new way to sell rock guard! FLEX-SEAL!
GA_Boater
works on rowboats with screen doors on'em. why not a starcraft...after a whole day on the water it still floats:D:D:eek:[/QUOTE
But no horseflies made it inside the boat. :p
Bwana Don
No I've never used it, and have no plans to. I think there are better choices out there. I recommend not using it. Gluvit is about $40 per quart plus shipping, this is the direction I went.
jbcurt00
Let me tell you a little tale about some bedliner, 3 different kinds of stripper that didn't work, a 3200psi pressure washer, the nastiest/harshest paint stripper I've ever seen & some chemical burns:eek: Oh and many not so pleasant hours of scrapping small 6" sq of bedliner at a time.......
Gluvit, $40
Taking about an hour to apply Gluvit, $20-500 (depending on your personal hourly pay rate)
Never having to strip truck bedliner off an SC double row riveted hull seam, PRICELESS plus 'Look ma, no chemical burns' so there's that too;)
  • You need to prep the hull to shoot bedliner, just like you'd do for Gluvit/paint (G/P)
  • Even if you go off the shelf from an auto parts discount place, the bedliner is going to be more expensive per unit then G/P
  • Your much more likely to plug the ends of the ribs & the limber holes, for hull drainage towards the bilge, w/ bedliner vs G/P
  • Bedliner is heavy compared to G/P
  • Bedliner is typically dark (or black), which in a tinny that's already prone to getting hot in the sun, may be counterproductive vs G/P
  • Bedliner is the anti-christ to remove vs G/P:mad:
  • See item above & repeat ad infinitum:D
That's my take away from my own personal tin boat resto experience w/ bedliner...... Your results may vary:rolleyes:
This is as it applies to the interior portions of the hull, and specifically the bottom areas across the boat from chine to chine and stem to stern across the ribs. Some, none or all of those statements could apply to other areas of a tin boat's part's and pieces, both those made of tin & made of other materials.....
And ultimately it's your boat, do as you see fit, based on your needs & wants, timeline, funding, access to 'normal' boat resto materials and other adaptable materials....
But yeah, that screen door boat guy needs to have an anvil dropped thru his treated screen door:facepalm: May have done just as much disservice to tin boats of all types as the people who started the pressure treated lumber rebuilds of tin boat................
InMotion
Gluvit, $40
So that's a no then?? :D
jbcurt00
Strangely enough, no it's not a no, it's a yes....:(
Oops sorry, it's not the Canadians that are the strange, upside down (backwards'?) sorta kinda english speaking people's.... That's the Aussies:facepalm:
You Starmada Canadians put the CAN in Canadian... Ever met a Can't-adian?
Not @these parts, bunch of go & getter done type guys:cool: Certainly not from the french influence:D
I meet Ain't-ericans and Ameri-can'ts occasionally too (you know, instead of Americans)
That ^^^ is all satire, I seriously don't mean to offend any of the multi-national cultures referenced above.
It is a resounding
Ab-so-freaking-loot-ly
no!:)
Captmills
jb seems a bit touchy on this matter:p
jbcurt00
Suffice to say that my MBS & the Admiral's PMS do not a happy home make :facepalm:
magnumdeke
Can I borrow this for my Sig line?? SOOOOO TRUUUU! and ah NO to the bedliner theory Gluvit please!
kickinitoldfool
Ok so I get it, LOL Thanks just wondering. Gluvit, Gluvit Gluvit!
jbcurt00
Fortunately, it isn't every 27days & sometimes not for more then 24hrs. Other times days & days & days & days & days & days & days:(.......
Kickin: It really is up to you, and my strong opinion shouldn't discourage you from using it, if you want to. There is a resto SC thread around here somewhere that did use a lot of bedliner material, just after he'd sealed the hull & rivets, and installed the deck...
A few glassers used it too. Maybe that should have been the basis of my argument: Don't do it like the glassers do it :facepalm:
Durabak & the other similar product 'looks' a lot like bedliner, but are more like epoxy paint w/ grit mixed in.
As long as it'll float & it'll be safe, I can usually cage the opinion w/ regards to others boats & their choices...
But seriously, I can't tell you how much getting it off sucked.....
Bwana Don
There are other threads here on Iboats about bedliner. I'll bet someone likes it somewhere. It's your boat so do what you think is right for you. We like pictures so post pictures for us and have fun working on your boat.
Just don't ask us if you should fiberglass your limber holes closed. Our heads will probably blow up.:facepalm:
barato2
actually finely chopped bits of rubber in both durabak and tuffcoat.
