Bearings Help needed.
k650
Hi all.
I have to change the 3 bearings in the transmission on my Evinrude 35hp -1959 cause of water in oil after long-time storage. The problem is that i cant see the numbers clearly on the bearings. Anyone that knows what bearing numbers it is? Not the OMC part number but the bearings standard number.
The part numbers are: 1 roller bearing 0375761, 1 bearing 20X52 and 1 roller type bearing 0376858.
Hope for answers.
Regards,
Fredrik, Sweden
mark1961
Ensign
Re: Bearings Help needed.
If you take all three to the local bearing supplier they should have no problem matching them up.....
F_R
The guy is in Sweden. If I had a unit torn down, I'd look at the bearings and post the numbers. But I don't have one. I'll bet somebody out there does though.
mark1961
Ensign
The wheel needs to turn in Sweden too.....im in Australia, we have them everywhere.....im sure Sweden has their share. It may well be what he ends up needing to do if no one has the numbers recorded or feels like tearing their LU down.....probably save him some time too.....take em straight to the "bank" i say.
k650
Hi.
Well, maybe that is the only way....take them to the dealer and find out.
k650
I dont think the fact that the bearings are inches is any problem here in Sweden, we have good availability on most parts. This is not the USSR :)
But it would be good to have the bearings id numbers.
mark1961
Ensign
All the bearings in the Evinrude/johnson are in inches, which makes the after market availability in Sweden rather limited.
I'd wager that i could take the bearings in my Evinrude LU down to a bearing supplier tomorrow and walk away with a new set in short order.....and we converted over to metric in 1966.
Sweden just happens to be the home of SKF.....the largest bearing manufacturer in the world.
Haffiman
But you are still 'suffering' from the British and as such need to 'double up'.:)
SKF might be a Swedish company, used to be great on ball and bearings, but not on needle cages. The European leader in that segment used to be INA (***) Apart from that, most of the SKF bearings are not made in Sweden anymore, got a huge factory here in Malaysia.Torrington that used to be the supplier to OMC, I belive has been taken over by Timken?
Things are not what it used to be, now Volvo is a Chinese car and Jaguar from India!!!!
The bigger Johnson 4-strokes are from Suzuki, and if you strip down some of the Yamaha 4-strokes you find Ford parts inside!
k650
My local SKF dealer had 2 out of 3 bearings, now shall i find the bearing with part nr: 376858.
Volvo is owned by the chinese, but is far from a chinese car. They are made and designed etc. in Sweden 100%. How many companies is not owned by foreign owners.
mark1961
Ensign
Like many other places we have no choice but to double up when both systems are still in use.....to do otherwise would make no sense.....American trucks, mining equipment and farm machinery etc has been imported here for decades.
mark1961
Ensign
Nice work, did you ask about ordering the final bearing in?
Yes, Jaguar is much the same in this regard but owned by India (sold to TATA by Ford)......the list of companies gets longer everyday.
Tim Frank
The 3756858 was either a Torrington AG28493, or an AETNA 5204-P.
SKF may be able to crossmatch if it was not a custom run for OMC.
I've seen lots of complaints about $$$$....seldom about availability.
Haffiman
Drawn cup needle bearings have always been a problem on the aftermarket side. Roller and ball bearings are a different story.
Most likely the local Timken dist. might be able to help:
Svensson & Svensson Ingenjorsfirma AB
P.O. Box 141
S-691 23 Karlskoga, Sweden
Tel: (46) (0) 586 - 371 50, Fax: (46) (0) 586 - 379 80
This should be the specs for the above mentioned bearing:
3110000782691
Terminal Board
BEARING,ROLLER,CYLINDRICAL
MFG P/N: 3110000782691
NSN: 3110000782691
MFG: TIMKEN AEROSPACE INC DBA TORRINGTON PRODUCT
Description: BEARING,ROLLER,CYLINDRICAL
Technical Characteristics:
Manufacturers code: 60380
Surface finish: ground
Overall outside diameter: 1.8499 inches minimum and 1.8504 inches maximum
Material document and classification: 66 fed std single material response outer ring sae 52100 assn std single material response roller
Design control reference: ag28493
Material: steel comp 8620 outer ring steel comp e52100 roller
Bore shape: straight
The manufacturers data:
Special features: no inner ring
Overall width: 0.8070 inches minimum and 0.8120 inches maximum
Bore diameter: 1.1097 inches minimum and 1.1108 inches maximum
Locating feature: one direction
k650
Great, thanks for all good advices .... :)
k650
There is one for only 47$ on Ebay, but he does not send international and is not possible get in conctact with.... :(
