Re: bearing races
Thanks y'all. I just got everything taken apart and I think I got it. While one side was okish, the side were the wheel fell off is missing both bearings the washers and castle nut. Also, no cotter pin in this set up apparently. In this version, there are two washers behind the castle nut, the outer one of which has as 90 degree tab on it that I suppose you fold down between the tabs of the castle nut (does it have a particular name?). Any who, I'm gonna get new bearings for each side (inner and outer), new rear seals and a new castle nut and washers for the side where the wheel fell off. Do I need bearing buddies with, or without the zerks, or can I just get simple "dust caps" to put over the end. I also noticed that behind the old bearing buddies which had their own grease zerks, is another zerk built into the axle spindle itself. Should I remove them and clean out whatever is in there? It looks like you can pump grease into the end of the axle and it will come out a small hole where the inner bearing would sit, presumably so you can grease them without taking everything apart. If so, should I pump them up with fresh grease until I see it exit the rear hole prior to reinstalling the hub assembly, or after everything is put back together? I'd love to get the whole thing preassembled, but I don't have a Northern Tools per se. I do have a Harbor Freight,NAPA, auto zone, etc... Would they carry them? Here are some pics of how I think my set up works.
Castle nut and washers. Does anyone know where I might find these without having to order it online?
http://www.trailerpartsdepot.com/itemdesc.asp?ic=5780K&eq=&Tp=
