Bayliner Shower Not Draining
tcc
cierra 2855 shower drain and switches not working. Manual of no help. will check with amp meter; wondering if anyone else had this problem?
gcboat
Re: Bayliner Shower Not Draining
Can you hear any noise from the motor or is it definately the switch?
If you find that the switch is just bad it really isn't that hard of a job to replace. No need going and buying an expensive "marine" switch when you can get the same piece from an auto parts store. Just slather up the connections good with some dielectric grease before installing.
Let us know what you find. :D
