bayliner outdrives
mikecreed57
Will the 270 outdrive enterchange with a 280 outdrive? Bolt pattern to engine?
PiratePast40
Re: bayliner outdrives
There are differences in some of the upper gearbox clamping ring to helmet bolts. Some use a double bolt arrangement and some are a single screw. There are also differences in lower gear ratios between all of them for 4, 6 & 8 cylinder engines. Tell us what you're trying to do.
