valentinec
Thread starter- Joined
- Jul 17, 2007
- 1
I own a 2003 Bayliner 285 with A.C. The A/C condensation drain flows from the drain pan down a flex tube into a housed bilge pump with a float swith. The enclosed bilge pump and swith box is located under the V berth. There is no power to the pump or switch and I can not find where the bilge pump and float power wire originates. I have checked all circuit breakers, the battery A/B breakers and around the battery terminals. Does anyone know where the power wire originates or where the problem might be (in line breaker, etc.)?????
Thanks.
Thanks.
