Bayliner 175 overrev with 21P?
severinbb
Re: Bayliner 175 overrev with 21P?
I took the data once. If I can find it I will share it with you. Obviously it's not 12% but the shape and weight of the boat dictates that it won't be too bad. I can get on plane in 2-3 seconds so that speaks somewhat for the performance of the hull at the lower speeds.
Mark
Hi. No big deal. Your performance sounds good. I was just curious what might be normal.
Here's what I found...
rpm
@30
slip
@30
rpm
@35
slip
@35
WOT
spd
WOT
rpm
WOT
slip
Alpha 4
20P
370019%420016%44515014%
Mirage Plus
21P
4447006%
Black Max
21P
380021%420016%44510013%
Rev 4
19P
360012%420012%4551007%
Laser II
21P
340011%400012%4750006%
HighFive
21P
360016%415015%44520015%
Bravo I
22P
320010%37009%4446509%
Tempest +
21P
340015%385013%46490010%
Another finding:
  • If I had a lot more power then the best prop would probably be different than the one I chose. It's not just about the numbers but also how the prop felt in specific situations. The Rev 4 scored big points in low-plane performance. Yes, I will have to watch I don't over-rev, but that's the compromise for good holeshot.
Texasmark
Hi!
Out of curiosity, what is your slip at "high cruise" versus WOT?
SB
Found the data:
On plane 18 mph slip 40%
20 35
25 26 This would be my comfortable cruising speed
28 22
32 20
38 12
43 11
50 9 All but pad out of water...less boat drag. See Avatar Pic.
Data taken in winter on a cold day. Numbers are GPS with just me in the boat. Altitude is about 800ft.
