battery voltage
spacerust
i have a 12v battery installed. when i try to crank her up the voltage drops down to about 9 or 10v. Is this right? or do i need a new battery? would this effect and cause a hard start?
JB
Re: battery voltage
It is pretty normal for battery voltage to drop to 9-10 volts when the starter is engaged.
Robj
Re: battery voltage
What is the voltage at when the starter is not cranking. It should be over 12.5 v, if it is less than 12, then you battery is getting tired.
Have a great day,
Rob.
dcg9381
Re: battery voltage
I think Rob means not cranking AND running.
dcg9381
Re: battery voltage
The value at the volt meter is subject to all sorts of parallel parasitic draw off of the other things that run on that battery - ignition for sure, probably lights - basically *anything* that's ON when the key is ON.
You'll have to learn the OK voltage for your electrical setup and gauge.
If you measure AT the battery, you'll get a much better reading. See how that compares to the gauge.
On my boat, running/charging, I see ~13V at the meter. Turn on the lights, which don't draw that much - but parallel off the same circuit, and I'll drop to 12.7 or so...
Measured at the battery, I see 12.2-12.7 (not charging)
12.9-13.7 charging/running.
