andraust
- Jul 29, 2018
- 4
I just finished installing a Perko battery selector switch on my Lund. This allows me to run my accessories off of a second, deep cycle battery. Install was easy and everything on the boat is running as it should. However, on my first time using the boat since the install, I have noticed that the voltage indicator is reading nearly 15 volts! That’s way higher than the usual 12-13V. On the way up the lake I had the switch set to Both batteries. Before heading home I selected just the battery 1 setting, but with the same high voltage results. Does anyone have any idea why this would be? Thanks.
