- Sep 26, 2009
- 20,471
2003 Johnson 60hp 4 stroke
J60PL4ST
3 phase rectifier
Checked with meter, not charging. Even have an alarm going off. Checked all connections, everything is tight no corrosion. Swapped battery with a 1yr old deepcycle, no change
Bench tested the rectifier.
Forward bias positive:
.66
.66
.63
Should the diodes read the same, or is a little variation fine?
Reverse bias:
All OL
Forward bias negative:
.63
.67
.67
Reverse bias:
All OL
Is the rectifier fine?
Thanks
J60PL4ST
3 phase rectifier
.66
.66
.63
Reverse bias:
All OL
.63
.67
.67
Reverse bias:
All OL
Thanks
