Re: Battery not charging
Thanks for the info. Testing the Rectifier seems tricky, I get very different reading from those suggested, but since I have fitted a new one and it is still not charging, it's reasonably safe to assume it's not that unless Ive been unlucky enough to fit a dud. Unlikely as the figures coming out of the new rectifier while running were the same as the old one.
Some more info...
- This outboard does have the second 2 wire regulator on top of the block, and another sealed, bigger black box beside it.
- When I tested the stator, I disconnected the two yellow wires from the rectifier and go the same reading from both at approx 30v ac
I still don't think it's the rectifier, but just to answer these ...
Instruction- "With all wires connected and the engine running at approximately 1500 RPM, check the DVA voltage from each yellow wire to engine ground. The two readings have to be within 2 volts of each other (i.e. if one is reading 20 volts, the other has to read between 18 and 22 volts)"
Result.... approx 6 volts from the rear rectifier post, 1.5 from the front post.
Instruction- "Turn the engine off and swap the stator leads. Crank the engine up and retest. The component that has the marking with the low reading is bad"
Result.... Same reading from both posts as before, with yellow wires swapped.
I will do some testing with the top Regulator disconnected and see what I get.
Many thanks.
Rich.
