Dutchlarson
Thread starter- Joined
- May 28, 2015
- 33
Hi Guys,
I have an issue with my 2004 Rinker 232 Captiva. This is my first boat with 2 batteries, and it has a switch for Bat1, Batt2, Bat1+2 and OFF. Before the season started i placed new batteries wich are both Marine spec 80ah battery, same as i took out.
So i took the boat out several times, and i only used the switch on battery one, also while at anchor. No problems.
Today i went out on the lake, still everything ok, but on the way back my radio kept turning off. After that, i noticed my trim switch didnt function anymore, so i conlcuded the power was low (voltage meter was still showing 13,5V).
Back in the dock i switched to battery 2, but it was completely dead!!
When i switched back to battery 1 i still had almost no power. However when i switched to Bat 1+2 everyhting worked fine again.
So, my question... Am i doing something wrong? Do i need to turn the swicht on 1+2 when i take the boat out so they can charge both? Or is my alternator dead?
Your help will be much apriciated!
