jtexas
- Oct 13, 2003
- 8,646
Re: Battery Drains While Boat Sits
when you did this:
You created this circuit:
You reported that the light stayed lit. The lamp in this circuit does not light up unless the solenoid is faulty. When you disconnected the starter motor from the solenoid the lamp went out, proving that current was flowing though the solenoid.
How do you know the battery is fully charged?
Replaced the solenoid today and connected the battery. I checked it 2.5 hours later and the battery was down to 60%, I started with a fully charged battery.
So I'm guessing it's not the solenoid. Could it be the starter or is it the wiring?
when you did this:
Negative cable on the neg battery post,
Positive cable disconnected,
Test light = clip on the battery (+) post, probe on the battery cable terminal. You'll need to affix it there (use a short jumper wire or aligator clip, or just tape it on there securely) or get a helper.
... Now, disconnect the fuse holder. ...
