battery choice
79project
what would be an appropriate battery as a cranking battery for an old mercury 1400? i just can't seem to find an answer i trust. cranking led acid sounds right to me, but i'm failing at figuring out a size online. as always, thanks for the help.
Re: battery choice
Standard marine lead/acid starting battery size 24 will work just fine
RMasters
Re: battery choice
What does the manual say?
My manual for the 1964 6-cylinder says it needs a battery with at least 650 CCA. I bought a regular 1000 CCA battery (as I hardly run any electronics when parked). Was a bit too tall, so I found a group 24 from interstate, 1000 CCA as well.
Turns this motor in no time, and plenty of reserve.
Ahoy!
j_martin
Re: battery choice
I've seen V6 racing motors started off lawn mower batteries.
Almost anything that isn't totally junk will work just fine. Wallet and personal preference can go from there.
