Bathing Your Cat
LadyFish
Some people say cats never have to be bathed. They say cats lick themselves clean. They say cats have a special enzyme of some sort in their saliva that works like New, Improved Wisk - dislodging the dirt where it hides and whisking it away.<br /><br />I’ve spent most of my life believing this folklore. Like most blind believers, I’ve been able to discount all the facts to the contrary -the kitty odors that lurk in the corners of the garage and dirt smudges that cling to the throw rug by the fireplace.<br /><br />The time comes, however, when a man must face reality; when he must look squarely in the face of massive public sentiment to the contrary and announce: “This cat smells like a port-a-potty on a hot day in Juarez.” When that day arrives at your house, as it has in mine, I have some advice you might consider as you place your feline friend under your arm and head for the bathtub:<br /><br />* Know that although the cat has the advantage of quickness and lack of concern for human life, you have the advantage of strength. Capitalize on that advantage by selecting the battlefield. Don’t try to bathe him in an open area where he can force you to chase him. Pick a very small bathroom. If your bathroom is more than four feet<br />square, I recommend that you get in the tub with the cat and close the sliding-glass doors as if you were about to take a shower. (A simple shower curtain will not do. A berserk cat can shred a three-ply rubber shower curtain quicker than Kerry can shift positions.)<br /><br />* Know that a cat has claws and will not hesitate to remove all the skin from your body. Your advantage here is that you are smart and know how to dress to protect yourself. I recommend canvas overalls tucked into high-top construction boots, a pair of steel-mesh gloves, an army helmet, a hockey face mask and a long-sleeve flak jacket.<br /><br />* Prepare everything in advance. There is no time to go out for a towel when you have a cat digging a hole in your flak jacket. Draw the water. Make sure the bottle of kitty shampoo is inside the glass enclosure. Make sure the towel can be reached, even if you are lying on your back in the tepid water.<br /><br />* Use the element of surprise. Pick up your cat nonchalantly, as if to simply carry him to his supper dish. (Cats will not usually notice your strange attire. They have little or no interest in fashion as a rule. If he does notice your garb, calmly explain that you are taking part in a product testing experiment for J.C. Penney. Cats are gullible that way!)<br /><br />* Once you are inside the bathroom, speed is essential to survival. In a single liquid motion, shut the bathroom door, step into the tub enclosure, slide the glass door shut, dip the cat in the water and squirt him with shampoo. You have begun one of the wildest 45 seconds of your life. Cats have no handles when wet. Add the fact that he now has soapy fur, and the problem is radically compounded. Do not expect to hold on to him for more that two or three seconds at a time. When you have him, however, you must remember to give him another squirt of shampoo and rub like crazy. He’ll then spring free and fall back into the water, thereby rinsing himself off. (The national record is -- for cats—three latherings, so don’t expect too much.)<br /><br />* Next, the cat must be dried. Novice cat bathers always assume this part will be the most difficult, for humans generally are worn out at this point and the cat is just getting really determined. In fact, the drying is simple compared to what you have just been through. That’s because by now the cat is semi-permanently affixed to your right leg. You simply pop the drain plug with your foot, reach for your towel and wait. (Occasionally, however, the cat will end up clinging to the top of your army helmet. If this happens, the best thing you can do is to shake him loose and to encourage him toward your leg.) After all the water is drained from the tub, it is a simple matter to just reach down and dry the cat.<br /><br />In a few days the cat will relax enough to be removed from your leg. He will usually have nothing to say for about three weeks and will spend a lot of time sitting with his back to you. He might even become psycho-ceramic and develop the fixed stare of a plaster figurine. You will be tempted to assume he is angry. This isn’t usually the case. As a rule he is simply plotting ways to get through your defenses and injure you for life the next time you decide to give him a bath. But, at least now he smells a lot better. <br />
SlowlySinking
Master Chief Petty Officer
Re: Bathing Your Cat
Here Kitty, Kitty, read this post and you'll know why no sane person washes cats. Thanks for the humor LadyFish, that's cute and so true,,
snapperbait
No, no, no, no, no... Ya got it all wrong... There is a much easier way... Safer too... <br /><br />The swirly bath method...<br /><br />First you clean the toilet....<br /><br />After the toilet is clean, add the shampoo of choice into the toilet water..<br /><br />Drop kitty into the bowl and quickly close the lid... Kitty's own thrashing around in the soapy water will create sufficient lather..<br /><br /> Flush to rinse.. Two flushes for short hair.. Three or more flushes is usually necessary for long hair...<br /><br />Open the lid and stand back.... (this is the only dangerous part) Kitty will fly out like it was shot from a cannon... <br /><br />After the swirly bath leave kitty alone... Kitty is quite capable to dry itself....<br /> :D
eurolarva
Giving a cat a bath is easy. Getting the hair out from your teeth is the hard part.
Parrott_head
My daughter gives our Siamese a bath about once a month. The cat has finally gotten to the point that he just stands there and makes a odd growling sound during it but puts up with it.
JB
Bathe a cat???<br /><br />Why not run naked through a cholla patch? Probably much safer.<br /><br />If Catzilla ever needed a bath she would be on her own. When she is upset, which is very easy to achieve, she is a dozen runaway chainsaws! :eek: <br /><br />Enjoyed the humor, LF, but get serious!! :D :D
SoulWinner
I tried bathing a cat we had years ago. She got sprayed by a male and I wanted to get the smell off her. She grew 8 legs, all of them with 20 claws. She got my arms, stomach, chest, face, head, back, and the back of my legs; in that order. We spend days so mad at each other, I bet she was planning my death in even more detail than I was panning hers.....
wajajaja
cats love catnip, and other weeds, easy wash then.
achris
More fish than mountain goat
I think I've just wet myself (from laughing). :D :D
Elmer Fudge
bathe the cat?...Hell! just shave that ..er..never mind, nuff said
samagee
Come on, use the dish washer. Then attach them to the ceiling fan in order to dry them out.
Skiuseme
I thought that you would put some soap in the toilet and put the cat in there so you can close the lid and sit on top. Rinsing is easy just give it a few flushes...
bvassel3
VERY funny LadyFish...great post! Thanks for the humor. BV
JasonJ
I tried to bath a cat once. Once. Even with the coveralls and welding gloves, I still sustained massive bleeding injuries, and mysteriously the cats legs grew to three times their original length, allowing the cat to stradle the bath tub with paws on each side, preventing entry into the tub. That cat never got a drop of water on it. I realized the next best technique: take to a vet and let them deal with it was a much better alternative. Now, I just leave them alone, they clean themselves... :)
beezee28
Bathe a feline?? Never!!! Being through it once and that is enough. The cat about about 8 months old and you would be surprise at what they can do. Not worth the trouble and injury.<br /><br />Good story, y'all
OMG ROFLOL ... lunch break, should know better than to open DC while drinking soda! :( Back to cleaning keyboard! <br />Good post LF!
