Bass Tracker console--->formerly 1974 70hp too big
wikelam
I have a 1981 16ft bass trackerIII. I have the 70 hp but it is to big for the boat. it is only rated at 60hp. I would like to find a 35 to 50hp motor to trade for the 70hp. it runs great but is to big. any suggestions on where to look.
Hooty
Re: Bass Tracker console--->formerly 1974 70hp too big
I'd put the 70 on it and never look back.<br /><br />c/6<br /><br />Hooty
Hooty
.... and being a '74 model, it was rated at the flywheel instead of the prop so it's something less then 70hp anyway.<br /><br />c/6<br /><br />Hooty
wikelam
it seems that someone before me had put a larger engine on it. the transom has dents in the back, they look like there was to much power. also i had to put gussets on it to firm it up. Also would the engine weigh to much for the boat. I have though about using it because it runs excellent, but i do not want to get into any trouble for using it.
wikelam
any help out there?
D
DJ
Guest
wikelam,<br /><br />There are plenty of quality used engines on this iboats site. Click on "Outboard Motors" at the top.
wikelam
i have looked at the motors on this site. most are over 2 grand. I am a mba student at oklahoma state uiversity and i do not have that kind of extra cash. the 70 hp i have runs excellent but is to big. so i dont want to go out and spend lots o cash when i have a perfectly good engine. i have a few people who want to swap it out for their smaller one but none of them want to actually go through with it. ALSO i would like to have a compression tester. are they easily attainable and at what costs?
wikelam
also does any one know if a steering console will work of a newer bass tracker for the 81 model. if so where would one start to look for one.
rwise
wikelam<br />all i have is too old for you! 1958 50hp
wikelam
yeh a 58 seems to old. <br /><br />I found a 1980 35hp evenrude. it seems a bit small though. does any one know if this will push the boat. i had a 63 sea king 40 hp on a boat about the same size and it ran ok(25-30mph).<br /><br />does any one have one of these motors and do you think it will push the 16ft almn. boat
wikelam
also, any ideas on the steering console mentioned earlier
SystemF
I just use an automotive compression testor. I think I got mine at Napa. Worked great to test the outboard and any auto engine.
jonboatbassin
Wikelam-<br />Ive got a 79 Evinrude 35hp that runs great that I'd be glad to trade for yours. Its on my 16ft boat and gets it up on plane with ease so you shouldnt have any problems with yours. Let me know if interested. Id be glad to take you for a ride in my boat to show the motor if you'd like<br />Thanks - Adam
papasage
i have a 74 5o hp wauld gladley trade but you are over a thousand miles away. i would keep what you have you dont have to run it wide open .i have 2 50 s 1-- 40 1- 33 1- 85 1 -65. bring that motor to georgia i mightb trade 2 for 1 and a bunch of extra parts. probabley could build another 50 hp . papasage....ben to stillwater 2 times it is a long wayes frome here . papasage10 @ yahoo.com if interested
wikelam
Any ideas on the console?
NathanY
What do you need in a console? Does your boat not have a console? You could just build one, it will be cheaper than buying one, and will give you the experience and satisfaction on knowing that you did it.<br /><br />Put the 70 on the boat. It will not hurt anything and it is no different than a 55hp 3 cylinder. <br /><br />But, if you are worried, I have a 65hp merc and am about 2.5hours from you.
wikelam
the console that was in it is trashed out. it is made from alumn. and is cracked and dented beyond repair. I have seen a few of the newer bass trackers and it looks like the consoles would fit perfectly. I just cant seem to find a used one anywhere. i have though about building it but if i can find one it would be easier. i have already totally restored the boats flooring and decking with wood and carpet so the satisfaction is already there.<br />the boat is only rated for a 60hp, but that is not my worries, the 70hp seems to be to heavy for the boat. I do not want the boat to be riding low in the rear because of the extra weight. that is why i am looking for a smaller motor. i have seen and drove a boat just like mine with a 40 hp merc and it worked great.
jonboatbassin
check out kvesurplus.com or kve-surplus.com.... not sure which it is. they have al kinds of boat supplies including consoles.
buttonhook
take your boat to a sheet metalshop (or area tradeschool) and see how much it would take for them to make or repair one.
