Hi Guys,<br /> I need to repair the floor on my pontoon boat due to a slight "accident". There's a spot on the floor where the plywood cracked/broke and when you step on it it is sort of springy. Other than expense, it looks to be a PAIN to strip everything off and try to get it all back on. I can get to the damaged area from underneath the boat. Any suggestions? Would a patch of plywood on the bottom work? The damaged area is slightly smaller than 1 square foot and unnoticable from the top until you step there. Then you sink about one half inch
