bass boat transom
hypnotoad
first post here, looks like a great forum. so, i bought a 78 glastron hp 154 bass boat, the transom is pretty rotted but seems pretty strong. I was looking it over to try and put together a game plan to remove the top but, it seems "glassed in" all around the back deck. i.e. the back deck has supports going down to the hull etc. I don't see any way to get the top off without doing some serious cutting around live wells/cooler and bench seat.
anyone ever replace a transom core in a bass boat?
Thanks
Rob
oops!
Re: bass boat transom
hey buddie.....welcome to i boats......
this is a really good site with lots of great people that know their stuff...
just about any question you have has allready been covered on these forums...from drying plywood to building hydrofoils.
just hit the search button
a moderator here did a transom on a bass bote...
i just saw it the other day....
search dj's post....
but ill have a look for you
cheers
oops
tashasdaddy
if i'm not mistaken, the cooler, storage compartment, console are all part of the upper cap of the boat. it all comes off. did one many, many years ago for my dad. it all came off as one.
oops!
hey toad....
i just searched the links and youll find the thread ....wet transom....
scroll down to dj's post and follow the links.
and if tashasdaddy says it will come off all in one...it will...years ago or not !.
read lots of posts here first...then start....ask as you go along.....no such thing as a stupid question....
cheers
oops
hypnotoad
Thank you for the kind welcome and replies,
I think I may take the sea cast route as there is no getting this top off, there are fibreglass walls that go from top to bottom and are glassed into the hull.
Thanks!
Rob
Chinewalker
Hi HypnoToad,
You'd be surprised. The seam is under the rubrail. The boat is made in two basic pieces - the hull and deck. Your boat's deck incorporates all that rear casting deck stuff. Remove the rubrail and you'll see the seam - remove whatever fasteners and pry it apart. You'll thank yourself in the long run, as you'll likely find other issues that won't be apparent by simply cutting the transom apart...
- Scott
stew6371
I know this is old thread, but did this project get done? I have a 1977 glastron just like it that I'm fixing to restore.
Bob_VT
I doubt it. That person only had 2 posts in almost 2 years.
Welcome to iboats! You are in the right place for a project. What do you have? You can start an entirely new thread and let this one just die.
Get familiar with the search feature and look up Glastron in the restoration section .....yes we have had many.
