lost all power to the prop after decelerating. went to throttle back up and the prop was not moving just a loud whine. took the boat to camp and messed with these springloaded fingers on the cable that goes to the outdrive. tried it on the land and the propeller spun so took it back to the dock and the video should be enough to finish the story. also, the lower part seemed to have a lot of water in the gear oil, and may have been low. the upper part (sorry about the terminology) seemed ok, little old but not bad. i saw on here there are clutches. the noise sounds dry, if its a clutch is it an easy fix? anywyas heres the video. how bad is it?
https://www.youtube.com/watch?v=MpBake6soHA
