grewvin1
Thread starter- Joined
- Apr 2, 2012
- 189
1986, 454, 7.5 engine. Backfire in exhaust manifold. pull left bank valve cover off exhaust rocker only moving 1/4 the travel distance of all the others. Valve springs good non broken portion of push rod showed travel mark as did all the others, this one showed it only moved small bit. if a collapsed valve can this be pumped up or is this a dead lifter and head needs to be pulled. oh ya lifter is at the bottom of the travel not stuck in the top end of travel.
