can a bad interupter switch cause no spark when starting the engine? I get no spark at spark plug.
P Pbarrett2 Recruit Joined Jul 5, 2018 Messages 5 May 4, 2023 #1 can a bad interupter switch cause no spark when starting the engine? I get no spark at spark plug.
1960 Starflite Chief Petty Officer Joined Jun 23, 2011 Messages 400 May 4, 2023 #2 If you're talking MercCruiser IO, the answer would be,Yes. But unlikely. More of a shift cable adjustment. Post in Mercury I/O section.
Alumarine Captain Joined Feb 22, 2005 Messages 3,760 May 4, 2023 #3 If you removed the leads attached to the switch that would eliminate the switch as the problem. Easy enough to check with a continuity tester to see if the switch works or not.
04fxdwgi25 Chief Petty Officer Joined Mar 25, 2022 Messages 607 May 5, 2023 #4 Deffinately a Mercruiser Alpha possibility It is usually the adjustment of the cables and / or a bad lower shift cable.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,426 May 7, 2023 #5 Pbarrett2 said: can a bad interupter switch cause no spark when starting the engine? I get no spark at spark plug. Click to expand... Ayuh,..... Welcome Aboard,...... Whatcha workin' on,..??..??
