bad gas tank sending unit?
bucko88
Hello
First post here.
I have a 1982 glastron with built in tank. The gas gauge always reads below empty. I have crossed with a wire from ground to s connection on the gauge and it goes to full so the gauge is working. I diisconnected the s wire from the sending unit and touched the ground wire from the gas gauge to the sending unit and it also went to full. I have a ground post on the tank and have my ground wire from the gas gauge connected to that post. when I remove the s cable from the sending unit and touch one of the sending units mounting screws the gauge shows full. I assume I have proper grounding. I have not taken out the sending unit as of yet and want to make sure I dont have a wire issue first. My question is does every thing sound like the wires are hooked up properly? I suspect a stuck float. What do ya'll think?
rpastor
Re: bad gas tank sending unit?
Most gauges have 4 terminals. The one for the light doesn't affect operation. Make sure the sender wire goes to "s", the ignition goes to "i", and that you have a ground wire attached to the "g" terminal. I have had a gauge problem, myself, due to an intermittent ground. If they are all good, pull the sender. If you have an access plate, it is very easy (5 screws). Sometimes, the float will develop a leak and fill with gas. Replacing it is as easy as putting a new one in. Moeller sells a universal where you set the length of the float lever yourself. The also sell ones that are specific lengths; you have to measure the depth of your tank.
