ATTN Starcraft SS peoples
Bob_VT
Okay.... I need a bit of help. My SS did not come with any dash panels.... wow what a basket case I started with.....
I need a few ideas and hopefully Pictures of your SS dashboards. This is just one of my hurdles.
I have access to..... white poly panel which is 3/8" thick and I could double it however, nothing will stick to it.... not paint not 5200 (it is similar to cutting board and it is white).
I have A-C plywood and epoxy......
I have oak but I have read too many bad things about it......
Pictures?
Suggestions?
I will have a steering wheel, a tach, and a few switches and that's it. I use a handheld GPS for speed.
Stratosman86
Re: ATTN Starcraft SS peoples
Bob, I am using cedar cut from an old headboard. Two coats of epoxy, sanded with 320 to make them like glass. Just my take, I think anything you want to use will be fine as long as you seal it!
Darren
STARCRAFT16SS
I love the look of wood with alot of grain in it...I used some hardwood,
stained it..then put several coats of marine varnish on it....now I wish I had
used epoxy on the wood dash and then used varnish over the epoxy to
protect the epoxy from the sun....next time I redo the dash.....:rolleyes:
I used stainless steel washers to lable the switches
My boat is 16ft...it might have a smaller dash then a 18ft boat
PS...Stratosman86.......I like the wood you picked out
HopeSheFloats
Run what ya brung...coat the oak with a couple coats of epoxy, followed by a few of spar urethane, with follow up coats of the urethane every couple of years as needed...
SS - self serving ;):p
Sorry, had to add it, as it's the only part of my resto I'm 'totally' happy with. :D
bananaboater
Ensign
I would not not do wood. You are in a great hardwood state. Find a piece you really like and go for it. Birds eye maple or fiddle back are among my favorites.
Bob_VT
Stratosman86 Very very nice! Do you think the epoxy will break down in the sun since it does not do good with UV?
STARCRAFT16SS do you think the spar will protect it being clear?
hmmmm decisions
Stratosman86
Bob,
I thought about that as well and put two coats of Spar Urethane on to finish it off. I am hoping this works, I guess time will tell, LOL!
Darren
86 century
Ensign
I like the wood but I need to hide my crappy wood work.
Andy in NY
hey bob what is the white poly panel you have? ive been looking for something like that for my dash...
Kainon
I tried using Starboard stuff once.. had it for about a year, didn't care for it much, I used 1/2". didn't like how the board expanded & contracted with the temp. dont know if it was me or the tools, but I didn't like
how the Gauges fit.
I prefer wood look but went for a nice strong precise cut of Alum, with CAD & machine cut Gauge holes.
Bob_VT
The plastic panel I have is large enough for my small dash.....it was an acid vat cover and NOTHING touches it ...... no effect from weather at all........ nothing sticks to it either.
Andy it's too small for your dash. :( unless you just need a 2' piece.
STARCRAFT16SS
Hi Bob VT....I have no experence using epoxy....I have been researching on
this web site how to do my transom and still have the wood show through..
that is my goal....
I checked out "Need marine plywood advice....."
there "tschmidty" suggested epoxy for waterproofing and spar varnish
over that for UV protection...
Another one I saw was "Jb weld or epoxy"
"Saildan" said you have to overcoat epoxy with paint, varnish or
gelcoat so UV doesn't break it down over time
In "Pulling Motor & Transom Replacement hints and tips?"
"sdunt" said Epoxy will yellow and degrade in sun unless you
varnish it and than you get to redo the coating every few years...
In "Waterproofing transom"
"Stoutcat" said Epoxy as a sealer...need to apply a UV resistant paint
or varnish/polyurethane on top or sun will break it down
Somewhere on this web site someone said varnish is not good for
waterproofing but great for UV protection and Epoxy is excellent for
waterproofing but but needs UV proction from the sun....
looks like if I use both....I might get the best of both worlds...I have not
tried it yet but plan to:D...sometime this summmer...I want to raise the transom height on one side of the stern and install a ss ladder that tucks-
away in a slot in the transom
ezmobee
1/4" Taco Marine Starboard with a plywood backer. Starboard is not technically glue-able with anything but a special glue. However, I used 5200 which is holding great now and they'll be further held in place with accessories. I'm not concerned and I like the no-fasteners look.
Andy, for your Jupiter you NEED to go to Lowes and get a PVC trim panel. Works awesome.
Bob_VT
EZ you might want to go from the back with short SS screws into the starboard on the PAX side. Trust me I think the 5200 will fail on it..... yes your's looks great
I decided I am going to go with oak. I put some epoxy and cloth on the back side to prevent splitting. I am not doing anything fancy but it will be durable when I am done.
ezmobee
