rayfiftyone
Thread starter- Joined
- Aug 18, 2009
- 8
I Have A 1984 470 Mercruiser I/o. For Several Years I Have Been Having A Problem With Acceleration. Sometimes It Will Get Up And Run But Lately Its Getting Worst.it Will Not Run Wot. The Engine Sputters And Dies But Starts Back Up Just To Do The Same Thing. I Have Rebuilt The Carb Twice With A New Accelerator Pump. I Have Changed All Ignition Parts. I Have Drained All The Gas And Added Fresh Gas With A Treatment.i Have Replaced All Fuel Filters And Lines. I Replaced The Check Valve At The Tank.i Removed And Checked The Fuel Pump For Diaphram Leaks And To See If It Would Pump Manually--it Does.most Of The Times The Boat Will Idle In Gear At The Lowest Rpm But Refuses To Accelerate Without Stalling. The Timing Has Been Double Checked, The Points Have Been Replaced And Set Correctly. Coil, Plugs, Rotor , Cap, Wires,all Replaced. I Pulled The Distributor Out And Manually Checked The Whole Thing , Including The Centrifical Advance Plates For Sticking. All Is Good. The Carburator Floats Are Free And Set Right At Spec.what Is Wrong With This Engine? It Always Ran So Good..
