Wassachu
Thread starter- Joined
- Nov 10, 2007
- 46
This is a serious fungus that's virtually impossible to remove. It's caused by decaying wood chips. Please refer to: http://plantclinic.cornell.edu/FactSheets/artfungus/artilleryfungus.htm
When they built my house in the woods in 2003 they cut the trees down, hauled off the logs and chipped the branches blowing them into the woods in a huge pile. Later I stored my 22ft boat near this pile on the edge of the woods. The next summer I started to see small hard shelled spots all over the boat on everything including the galvanized trailer. Scraping these spots leaves a small black tary substance. I haven't found anything that removes these stains from my fiberglass. I have a huge list of cleaning agents and chemicals that failed including: bleach, acetone, MEK, paint thinner, On/Off bottom cleaner(contains a mild acid), rubbing compound and on and on. I've had two pro's look at it and the final opinion is to use 1000 grit wet/dry sandpaper, sanding wet, followed by a good rubbing compound, a buffing compound or polishing compound and then wax. A lot of work. Articles I've read on this all talk about spots on cars and home vinyl siding. My boat is a 1990 so the gelcoat has seen a lot of sun and needed more wax so that made it worst.
Spores from the decaying wood chips a propelled about 20ft in the air and are attracted to the sun or anything that reflects the sun, a white boat. I have thousands of these spots from the hard top to the keel on glass, aluminum, stainless steel and fiberglass.
This thread is to alert as many as possible. Please keep your valuable toys away from wood chips. I'd hate to see anyone go through this.
