rbc
Thread starter- Joined
- Apr 18, 2004
- 71
I have a 15' boat that I wish to hang from davits. I don't want to use conventional spreader bar as they are heavy cumbersome,etc. I want to use 5/8 dock line which is plenty strong for a 1300 lb. boat. Bow is easy with bow hook in bow for lifting. If I use stern davit hooks that are on boat the rope would form a triangle from hooks up to davit cable hook. I think this would be very unsteady and boat could tip easily.
My idea is to use a piece of sched. 40 PVC to act as a spreader in order to spread hang lines out to boat hooks. I would drill hole thru each end of PVC and pass line thru it then up to davit hook. There would be no upward pull on PVC as lines just pass thru it. But my question is would there be a lot of compression on the PVC that just acts as a spreader? The PVC is fairly strong as I can hardly put any bend in it by leaning hard on it.
What do you think?
thanks
RBC
What do you think?
thanks
RBC
