Arco Power trim motor loud
P3FE
I have a 50 HP merc 2 stroke, ELPTO. The trim motor was rusted out bad, so changed it with an ARCO and now the motor sounds quite a bit louder. Has anyone had this happen to them? Is it normal for the ARCO motor to be louder? Thanks:)
RRitt
Re: Arco Power trim motor loud
You can't say one way or another. You have to touch the motor to a battery before it is installed. It should spin & hum without vibration, clanking, or loud noise. If it has noise or vibration then the bearings or magnets may have been damaged in transit.
the arco spins faster than pre 1996 trim motors. the system will be more noisy just due to increased rpm. it also may need a different driveshaft and you could be hearing driveshaft rattle. It's nearly impossible to say whether it is motor or system when they are attached together.
