FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a Year 2000 Aquasport 215 Explorer. I need to replace the electronic fuel gauge sending unit. The port hole in the deck is off center from the sending unit located on top of the gas tank, by about 4", can anyone tell me how to replace this?
You may need a curved screw driver. You may also want to check to see if your tank has shifted over the years. Mine did the same thing and the only way to get the tank back on center was to empty it to make it more manageable to slide. Once its back on center, you should be able to access the sending unit.
Were you ever able to replace the fuel sending unit? I have the exact same problem with my 2000 Osprey Sport - the sending unit is off center from the deck plate hole.
