Aquasport 29ft sportfisherman
kennv
Does anyone know where i can get the specs for my 29ft Aquasport tournament master. I need to find out what the prop pitch is supposed to be. I can not get my RPMs over 3000 on twin 350's. Top speed 16 knots frustrated.
steelespike
Re: Aquasport 29ft sportfisherman
What System? Merc.OMC etc
What drive Alpha1?etc.
Your prop size should be on the prop near the base of the blades or under the prop nut,
the gear ratio should also appear on the outdrive.Also what year is the boat?
While thats not what you asked for your max rpm and speed with the prop size should tell us if your props make sense.
kennv
I have twin inboard remaned mercs 5.7Lt . I checked the props and on the shaft part of the prop it says 18 LH 18 and 18 RH 18 , what i need to know is what the correct prop pitch is for this boat so I can find out if the props were changed prior to me buying it.
steelespike
I think you need to post youre question at classic aquasport.com
It appears the 290 with 350s came from the factory with 18 X 17 props.
As a poster discovered by calling all over the east coast.
Don't know if the 350s have gear reduction.
Another with 454s has settled with a 17 X 16 though hadn't tested when posted circa 2010.
17X15 were running a bit over 4600 thus the 17X16
