AQ130c idle and 270 drive clunk
captmello
Re: AQ130c idle and 270 drive clunk
Success!!!
I cut grooves in the oak board which created more surface to grab the shaft.
[/IMG]
I got out the 3 lbs hammer like PP40 said. I don't have the correct socket so I used my trusty 30mm open end wrench. Who'da thought I'd ever use that wrench? I'll have to buy a socket to torque the nut for assembly.
[/IMG]
I only had to back the nut off a few turns to loosen it just enough to get the clips to fall right out.
Heres the washer and clips. clips and washer slipped right off.
[/IMG]
I'm hoping the new brass washer will tighten up my top nut clearance.
The washer has a groove worn in it on the side you can't see when its installed. Hard to see in the pic.
[/IMG]
I'll order the new brass washer and clips and we'll see how it works next spring... I'll update when I install the new parts, to see what my new clearance measurement is.
thanks to everyone for the help, I hope pcmpete updates us as well.:)
pcmpete
This was looking to be a bigger task than I first thought and was considering taking the upper unit a professional to do it for me, but after seeing the idea with the oak on the vice and will try it myself first.
captmello
Let us know how it goes.:) Check your clearence first. See what you're starting with and let us know.
captmello
I received the new brass washer and clips and installed them. My new clearence measurement is .014 which is within specs so I was happy to see that.
I put in a new seal under the top cover as well as a new oring at the one cap bolt and buttoned it up.
I hope pcmpete has similar results and it helps with his shifting cluck.
pcmpete
I wish, I haven't got round to the upper drive unit yet. I am trying to finish a rewiring project on the boat before i start, and with the holidays and now bad weather time has not been my best friend lately. Glade you got good results with yours captmello. I look forward to the 'in water' results from you.
