pcmpete
Thread starter- Joined
- Apr 24, 2009
- 328
I am getting serious blow-by and loosing alot of oil. Little smoke from the exhaust but alot of oil around the engine, especially the front. Can the blow-by effect blow gaskets and seals.
At idle, when I remove the oil filler cap the rpm would increase by approx 100rpm.
The dipstick level would go from full to nearly off the stick in a 4 hour trip (25% of time in No-Wake zones to pulling tubes and general WOT)
I finally got round to taking a compression test, results below.
From these results and the blow-by can I safely say that my piston rings are shot?
Or is there something I should be looking for.
AQ130c Aug 2009
Compression Test Results
Dry Cylinders (psi)
1. 125
2. 150
3. 150
4. 140
10ml Oil in Cylinders (psi)
1. 150
2. 175
3. 180
4. 175
Thanks for your time.
AQ130c Aug 2009
Dry Cylinders (psi)
1. 125
2. 150
3. 150
4. 140
1. 150
2. 175
3. 180
4. 175
