steve242002
Thread starter- Joined
- Apr 26, 2009
- 17
Hi guys, I have a 1986 or so AQ125A. It runs pretty good but my compression is only at 80PSI across all four cylinders. I was reading in my book that it should be around 140to 170, give or take. I talked to my local volvo dealer and they told me it might be better to just buy a new engine rather then rebuild this one becasue it would be well over $3K. I am in to this darn boat/engine around $4K and have had it in the water one time, this last Saturday and had to get towed in due to an overheat problem. My question is do I have to use Penta parts or can I use standard auto parts like from NAPA. If so, should I bore over .010" and just replace rings or do I need to replace piston and rings, and rods, and so on. What type of car has the same block as the AQ125A block? Any suggestions would be great!
