AQ120B Carburetor rebuild kit
Status
Not open for further replies.
Hitech
Once it?s warmed up it runs fine at idle. After five minutes of running or so it does not want to idle. It will typically start back up at run for 5 seconds or so and then start to die. Even giving full throttle does not keep it running.
I attached an external outboard type fuel tank directly to the fuel pump and got the same results. I have also checked the fuel screen in the fuel pump and it is clean.
So, I?m thinking I should rebuild the carb. Any one know where to get a kit? I believe that it is a Solex 44 PHN 3.
Thanks, as always. :D
Hitech
Re: AQ120B Carburetor rebuild kit
Bump
oldrenken79
I got my rebuild kit right here at I-Boats. I called them directly on the phone and it was delivered within a few days.
Solex number is 44 PHN 3 and the kit number is SO-69K.
Have a good one!
Don S
July 13th, 2008, 06:21 PM
Read the archives don't reply to them.
Status
