apparent miss under load
jthughes68
I have a 1990 Force 120. Under load it has a random "slam" or "bang". It feels like you've hit a stump, as you can feel it and hear it. Changed props and checked oil for metal and found none. I believe it is a misfire, but not sure, as it doesn't do it at idle.
Aggitated
Re: apparent miss under load
Lots of luck with this one my 85 hp is doing the same thing. So far it's been a months long project trying to figure out the problem. If i can help in any way let me know.
David W.
Frank Acampora
Either the drive dogs are worn or the shift linkage is incorrectly set. The bang you hear is after popping out of gear it drops back into mest and since the engine is running way faster than at idle it bangs rather than the normal clunk you hear upon shifting.
SO: First thing to do is to be certain that the shift linkage has equal throw in each direction and that the full throw in forward (down) fully engages the forward drive dogs.
Looking at these photos you can see the relation between the pinion, drive gears, and dog clutch. In the last photo, one of the adjustment points is below the transom clamps where the upper and lower shift linkage is held together. If you remove the pin and rotate the lower rod counterclockwise it lengthens the linkage and biases toward forward. Do not go too far or neutral will be in gear and reverse will be neutral. Try about 1/2 turn at a time. If after a couple of turns, it does not improve, the drive dogs are worn round and must be refinished or the whole gear pak replaced.
foodfisher
Hey! thought the new wife absconded with you. Good to hear a calming voice again. Sorry jthugs68 for the jack.
Frank Acampora
Ahhh! I was in Atlantic City for a week! Did so well in the casinos that I went in an 80,000 dollar Mercedes and returned in a 500,000 dollar bus! LOL
