Anything wrong with Insert Image button functionality on the thread editor?
DeepBlue2010
Guys,
I am trying to upload a picture to a reply thread and I am following the same steps I followed before but the user interface is not responding.
When you click on Insert Image button, a screen appear as usual with From Computer and From URL tabs. From Computer allows you to select files from your local file system but when I click on Select Files, nothing happened!!
I tried 3 different browsers and had the same exact results. Anyone else experiencing this issue or it is just my machine acting up?
roscoe
Re: Anything wrong with Insert Image button functionality on the thread editor?
Doesn't work for me.
It never has.
I scroll down just below the reply box, and select the "Go Advanced" button on the right.
Then scroll down to the "Manage Attachments" button in the center of the page, about half way down.
A pop up window will open, in the upper right hand corner is a "add files" button.
Click the add files button, which will give you a "choose file" button.
Find your file on your computer, click "choose". You can choose up to 5 images to upload.
Click "upload".
Then click the "insert inline" on the bottom of the window.
Then "done" to close the window.
This will put a clickable thumbnail in your post.
Go advanced
Manage attachments
Add files
Choose file
Upload
Insert inline
Bob_VT
I actually had the same problem yesterday and I thought it was me. I never had the problem in the past. I will let IT know.
toneeees
Administrator
Are you guys still experiencing issues with uploading images?
WIMUSKY
Nothing is happening when I hit the Select Files button......
DeepBlue2010
Still nothing happens when I click the Select Files button
DeepBlue2010
It never has.
Click "upload".
Go advanced
Manage attachments
Add files
Choose file
Upload
Insert inline
This approach ends up throwing an error..
The following error happened
Upload of file "xyz.abc" has failed
colbyt
Master Chief Petty Officer
testing.
You can do it but you have to click on the basic uploader link.
Bob_VT
Yes, the SELECT FILES button does not work - just tested.
Remember Toneeees I am running Chrome.
DeepBlue2010
Any updates from IT?
icyveins
still nothing, I have tried at home and work using the "select files" also tried using the basic uploader and that failed as well
toneeees
Administrator
toneeees
Administrator
toneeees
Administrator
I'm not sure what the issue is, I've uploaded and inserted images thru attachments. When you select the image icon, and it pops up the window with "Select Files" click "Basic Uploader" select your file, then click upload files. It inserts the image into the post automatically. I'm using Google Chrome as well.
Nothing has been changed that would effect this, I'm not sure if "Select Files" ever worked or was ever meant to be clickable.
Bob_VT
Well it is now working ONLY if I switch to the "Basic Uploader" Yes, it used to work fine.
alldodge
It's doing it again, even switching to basic uploader allows for selecting files but will not upload when upload is selected. I'm running IE10 on a 64bit computer
alldodge
Haven't heard anything, I still cannot upload, just finished trying. Anyone else still having trouble?
DeepBlue2010
both basic uploader and the File Upload Manager (from the advanced -> attachements) fail to upload the file with error. I noticed that only the moderators have no problem with this; could it be a access level issue. Moderators, would you please try from a less previledged account that is similar to ours?
UncleWillie
Just confirming...
*** Insert Image > From Computer > Select Files *** No Longer works.
It has worked for years up until a few weeks ago.
The Basic Uploader works to load one picture at a time.
alldodge
Just confirming...
For me the basic up loader is a roll of the dice, it doesn't work often then it does
