Anyone heard of Supermarine marine paint
jbcurt00
Re: Anyone heard of Supermarine marine paint
Probably not going to find a bunch of iboater's that have used any $200+ per gallon paint. That's based in part on being under the impression that many here, choose to work on their boats because they HAVE to so that they can afford the boat & all that it's ownership entails.
Use the advanced search function above in the blue banner across the top of every forum page. It found 30+/- threads where it's mentioned.
I'm pretty sure Andgott is extremely happy w/ it on his Glasspar:
1961 Glasspar Citation Project
I'm using the Supermarine paints- So far, I've got the primer done on the whole boat, and SHOULD be painting the deck/topside this week, if I get my thinner!
I've experimented with their topside paint a bit, and so far I like it. I'm using a red, and I have had some coverage issues, but that's normal with a deeper color like that. I've switched to a deep colored primer, and hopefully that'll help me get more even coverage with the paint.
I went with these paints because I liked their gloss and durability, but they are still a one part paint that's a little easier to work with. I've used all different types of paint on boats- Everything from deck & porch paint to awlgrip, and just about everything in between. I wanted to find a paint that would have a high gloss, last a long time, but wasn't overly difficult to apply given the equipment I have on hand.
There are a LOT of different ways to go with paint, but you've got to balance out the pros and cons of each system, and find the paint that suits your needs the best. Plain old Rust-O-Leum does wonders, and is cheap. single part Polys are easy to apply, and offer great gloss, but cost a lot more and, at least in my experience, are a bit softer and require reapplication more frequently to keep up the shine. You can get in to a multipart paint, too- Which usually is going to last longer and be more glossy, but requires more attention and equipment to apply properly.
Just remember, whatever paint you choose, the key is the prep work... If the surface isn't perfect, you can use the most expensive, best paint in the world, and it's still going to look terrible. Some paint 'systems' require a certain type of primer be applied, that is compatible with the topcoats. Keep that in mind before choosing a primer!
-Andrew
And if I'm not mistaken also used it on his 1959 Lake N' Sea Restoration
Are you going to use the SuperMarine paint on her as well?
Yes, But I'm not sure which of their paints I am planning to use. I might try the two-part urethane- The techies there have been trying to get me to try it out. I do know that I'm going to be using their epoxy primer.
Best of luck w/ your project
Njangler
Thank you will do. I used the quick search. So I will follow you lead. Not looking to spend too much on paint for a dyi. I was just trying to find the best paint and primer for the money that I can roll and tip.
jbcurt00
It isn't going to be a showroom quality finish, but most of us DIY painters are looking for a 5-10ft paint job and 'good enough'. You might try reading thru WoodOnGlass' paint link:
"Paint Your Boat for Under $100 Bucks...Well Almost"
Good enough doesn't mean careless or poorly done, just that for the time & money, it was an acceptable compromise.
Prep prep prep.
I plan to use Ace Hardware's rebranded Rustoleum paint, w/ enamel hardener, and if I can swing a good space to spray it, spray it. Else I too will be doing roll/tip or roll/roll... The 1st project to get color will be the Duracraft aluminum boat in my signature below. Many of WOG's paint tips work for both glass & tin boats.
BTW: Ace hardware will tint their brand of paint and primer, so hopefully, I can get away w/ good coverage over the pre-tinted primer.
LOTS of good paint tips spread across the resto section, look thru there too..
Njangler
I am starting a thread on my 1960 Owens.
TregoMark
I used Supermarine on a project I did a couple of years ago. You can see the results here:
http://forums.iboats.com/completed-boat-projects/sea-king-project-complete-469777.html
I didn't brush it on though. I used a gravity feed sprayer. The paint is very high quality, but temperature sensitive when applying. It has to be applied in the specified temp range. This was my first attempt at anything of this sort and I think I did fairly well. At least until I tried to apply a clear top coat from Supermarine. I rushed it and the results were bad. The coat yellowed and ran in places. It was quite a mess. Best advice is to take your time, follow the directions to the letter and contact the company with application questions. Or use something else like Rustoleum boat paint.
