Any tips on removing old fun-fur adhesive
popeyefoghorn
hi, I have a '78 Chris Craft Catalina Express 29'. I have been restoring the interior and started to remove the old white fun-fur from the ceiling. I was wondering if there are any good tricks to removing the adhesive? Also I was wondering what other people have used as a new interior ceiling covering. thanks
tashasdaddy
Re: Any tips on removing old fun-fur adhesive
acetone. custom headliner shop.
Robj
I agree with TD -acetone. When I replaced my hull liner, I just used outdoor carpet, it was the cheapest option and looks great. Something that you may want to consider.
Have a great day,
Rob.
Old Salt Oz
Take care,
Acetone is toxic flammable and a carcinogenic, its use requires protection for your eyes, skin and lungs with no naked flame or sparks.
Use only in a well ventilated area.
Avagoodweekend......
Speakrdude
Ensign
Hey Rob. I sure would like to see some pics. Thats a great idea.
Jim
SgtMaj
Acetone also dries VERY fast which can make it more difficult to use. An alternative would be rubbing alcohol, it doesn't dry as fast, but also doesn't work as well. But if you start with that and finish with acetone, you'll probably find it much easier than using either one by itself.
popeyefoghorn
thanks, i'll try that, now what did you use to secure the indoor outdoor carpet? the inside of the cabin has a curved edge on the sides, so how hard would it be to get the carpet to fit snug?
mudmagnet63
POPEYE look for 3M 76 High tack spray adhesive easy to use quick set time.
if you use it experiment with a small piece first
