another prop question
gotmeaboat
long time reader, 1st post. i just bought a Hydra Sports 1850 center console, equiped with a Johnson 150 Ocean Runner. how do i find out the right prop for this rig?
thanks:confused:
steelespike
Re: another prop question
Welcome, If there is a prop on there now numbers may be on the hub or under the prop nut. We will need more info to make a prop selection without your prop size
and present max rpm and speed.Would help to know the weight of the boat or at least the year also the year and max rated rpm of the motor would help.hwsiii has a form to fill out.Check some of his posts.
Also if you read the stickies at the top of the page and helps on the prop store page it may help you understand prop selection better.
