stevenhickeys
Thread starter- Joined
- Aug 1, 2012
- 53
Hello,
I picked up a StarCraft American 20 with a 165 Mercruiser and MC-1 outdrive. This boat has not been in the water for some time. I'm noticing the motor temp is going up above 180 while it is idling in my driveway with the muffs on after @ 10 minutes of running.
Over the winter I am having the seals changed in the O/D and will have the impeller replaced. Even though the impeller is old it does seem to pump water through the system.
I am hoping it is a stuck thermostat so when I get home from work, I will pull the thermostat and test it in some hot water.
Would it be advisable to run the motor w/o the thermostat to make sure the temp does not go up?
Thanks in advance for any information.
SH
SH
